[Qgis-user] Install Qgis on Ubuntu 14.04
custard custard at westnet.com.au
Fri Jun 13 02:17:25 PDT 2014
On 12/06/14 18:10, Carmine Massarelli wrote:
> Dear all,
> I am not able to install qgis 2.2 with ubuntu 14.04 LTS. I saw a guide
> to view .ecw file with 2.2 installing SDK from ERDAS but not in 2.0.
> Someone can help me to explain the procedure to let seeing .ecw file in
> qgis 2.0 or to install 2.2?
> Thank to all
The process should be similar in both. Which guide where you looking at?
2.0 is in the standard repositories.
If you want 2.2 then probably the easiest way at the momment is to
remove QGIS 2.0 and then added in QGIS from this source:
http://www.qgis.org/en/site/forusers/alldownloads.html#on-plain-ubuntu
-ramon.
