[Qgis-user] Install Qgis on Ubuntu 14.04
Yasser Said Lopez de Olmos Reyes biolyasser at gmail.com
Fri Jun 13 06:32:16 PDT 2014
It works for installing QGIS stable (2..2, right now). But I really don't
know anything about this ECW file extension. Is it supossed to be supported
in 2.2 but not in 2.0? If the quiestion is how to install QGIS 2.2 in
Ubuntu 14.04, use my instructions and you'll get there, but, again, I don't
know how QGIS 2.2 will perform with ECW files.
2014-06-13 4:17 GMT-05:00 custard <custard at westnet.com.au>:
> On 12/06/14 18:10, Carmine Massarelli wrote:
>> Dear all,
>> I am not able to install qgis 2.2 with ubuntu 14.04 LTS. I saw a guide
>> to view .ecw file with 2.2 installing SDK from ERDAS but not in 2.0.
>> Someone can help me to explain the procedure to let seeing .ecw file in
>> qgis 2.0 or to install 2.2?
>> Thank to all
> Hi,
> The process should be similar in both. Which guide where you looking at?
> 2.0 is in the standard repositories.
> If you want 2.2 then probably the easiest way at the momment is to remove
> QGIS 2.0 and then added in QGIS from this source:
> http://www.qgis.org/en/site/forusers/alldownloads.html#on-plain-ubuntu
> -ramon.
> Qgis-user mailing list
Saludos,
Yasser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140613/1ec0f6cc/attachment.html>
