[Qgis-user] How often is rebuilt qgis-dev in OSGeo4W?
Jürgen E. Fischer jef at norbit.de
Fri Jun 13 07:32:43 PDT 2014
Hi Junior,
On Fri, 13. Jun 2014 at 16:06:48 +0200, Junior Delaz wrote:
> Sorry but I d'on't really understand what i might look at in the .ini link
> you sent.
It lists all installable packages.  Currently for the qgis-dev package:
@ qgis-dev
sdesc: "QGIS nightly build of the master"
ldesc: "QGIS nightly build of the master"
category: Desktop
requires: msvcrt qt4-libs libpq gsl-libs proj geos gdal gdal-python spatialite zlib grass python-core sip pyqt4 qwt5-libs-qt4 iconv fcgi libspatialindex psycopg2 osgearth-libs python-qscintilla oci python-jinja2 python-markupsafe pygments python-dateutil pytz
version: 2.3.0-100
install: x86_64/release/qgis/qgis-dev/qgis-dev-2.3.0-100.tar.bz2 38534980 413bdd4f4c6a0af959237cd1befc60fe
[prev]
version: 2.3.0-98
install: x86_64/release/qgis/qgis-dev/qgis-dev-2.3.0-98.tar.bz2 38490399 774088d3efeff6915e1d731f33faa7f1
So you should see 2.3.0-100 in the installer and you have the option to
alternatively go back to the previous one at 2.3.0-98.  If your setup.ini looks
different it's old.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
