[Qgis-user] Install Qgis on Ubuntu 14.04
Andre Joost andre+joost at nurfuerspam.de
Fri Jun 13 08:13:00 PDT 2014
Am 13.06.2014 16:24, schrieb Carmine Massarelli:
> The guide to install SDK to read /.ecw/ is here
> (http://permalink.gmane.org/gmane.comp.gis.osgeo.ubuntu/870), but does
> not work in qgis 2.0, maybe i need qgis 2.2.
The guide is for Ubuntu raring, using ubuntugis unstable repository.
For ecw support, you need the package libgdal-ecw.
This is at the moment only available for precise (12.04) and
raring(13.04), not for saucy (13.10) or trusty (14.04).
So it's more a question of ubuntu version, not qgis version.
> So can I follow your instruction?
> 1) open a terminal
> 2) gksu gedit /etc/apt/sources.list
> 3) enter password
> 4) add this lines in the end
> deb http://qgis.org/debian trusty main
> deb-src http://qgis.org/debian trusty main
This is not using ubuntugis repositories at all, so you might be out of
luck with ecw support. Mixing both repositories, and different Ubuntu
versions is likely to fail (unless you know exactly what you are doing).
HTH,
André Joost
