[Qgis-user] Extract Projection Hangs
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Sun Jun 22 06:04:38 PDT 2014
You can use listgeo command in OSGEO shell:
listgeo -tfw DTM_MULTI-HS_D8_H25.tif
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Rebecca Bennett
Sent: 22 June 2014 12:13
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Extract Projection Hangs
Thanks for the tips on using gdalsrsinfo Andre.
I can confirm that the tifs do have a projection assigned (see output
below), but that the extract projection tool still hangs when I attempt to
create the world file:
C:\Users\Rebecca\Desktop>gdalsrsinfo
C:\Users\Rebecca\Documents\DTM_MULTI-HS_D8_H25.tif
PROJ.4 : '+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
+y_0=-1000
00 +datum=OSGB36 +units=m +no_defs '
OGC WKT :
PROJCS["OSGB 1936 / British National Grid",
    GEOGCS["OSGB 1936",
        DATUM["OSGB_1936",
            SPHEROID["Airy 1830",6377563.396,299.3249646000044,
                AUTHORITY["EPSG","7001"]],
            AUTHORITY["EPSG","6277"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4277"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",49],
    PARAMETER["central_meridian",-2],
    PARAMETER["scale_factor",0.9996012717],
    PARAMETER["false_easting",400000],
    PARAMETER["false_northing",-100000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","27700"]]
Does anyone have another way to create worldfiles from the embedded geotiff
data? I suppose I could do this by hand for each file but ideally I'd like a
neat solution for batch creation across a directory (like extract projection
used to offer!).
Many thanks,
Rebecca
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140622/aa8acc33/attachment.html>
