[Qgis-user] Extract Projection Hangs
Rebecca Bennett rabennett at ymail.com
Tue Jun 24 05:54:50 PDT 2014
Thank you to everyone for your suggestions. I worked around the problem using GDAL in the command line.
Would be great to know what's happening with the extract projection tool though... I will submit a ticket.
Cheers!
Rebecca
On Sunday, 22 June 2014, 14:05, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk> wrote:
You can use listgeo command in OSGEO shell:
listgeo –tfw DTM_MULTI-HS_D8_H25.tif
From:qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Rebecca Bennett
Sent: 22 June 2014 12:13
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Extract Projection Hangs
Thanks for the tips on using gdalsrsinfo Andre.
I can confirm that the tifs do have a projection assigned (see output below), but that the extract projection tool still hangs when I attempt to create the world file:
C:\Users\Rebecca\Desktop>gdalsrsinfo C:\Users\Rebecca\Documents\DTM_MULTI-HS_D8_H25.tif
PROJ.4 : '+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-1000
00 +datum=OSGB36 +units=m +no_defs '
OGC WKT :
PROJCS["OSGB 1936 / British National Grid",
    GEOGCS["OSGB 1936",
        DATUM["OSGB_1936",
            SPHEROID["Airy 1830",6377563.396,299.3249646000044,
                AUTHORITY["EPSG","7001"]],
            AUTHORITY["EPSG","6277"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4277"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",49],
    PARAMETER["central_meridian",-2],
    PARAMETER["scale_factor",0.9996012717],
    PARAMETER["false_easting",400000],
    PARAMETER["false_northing",-100000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","27700"]]
Does anyone have another way to create worldfiles from the embedded geotiff data? I suppose I could do this by hand for each file but ideally I'd like a neat solution for batch creation across a directory (like extract projection used to offer!).
Many thanks,
Rebecca
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140624/e70e63f3/attachment.html>
