[Qgis-user] QGIS Web Client with Google Background Maps works only in EPSG 3857
Bernhard Ströbl bernhard.stroebl at jena.de
Wed Jun 25 04:16:10 PDT 2014
GoogleMaps is only available in GoogleMercator projection (3857), so if
you want to use them you have to use this projection (in which case I
would recommend to also reproject your data for the server, so QWC, the
QGIS project and the data are in the same projection.)
BTW: The GoogleMap is also not included in the print.
Bernhard
Am 25.06.2014 13:05, schrieb Markus Weidenbach:
> Dear List,
> I am running QWC on a Remote Debian 7 (QWC checkout from GIT HUB on
> 25.06.2014) and on a local Win 7 (checkout in Marc 2014) computer.
> I would like to publish my QGIS projects in its original CRS, which is
> EPSG 31467 together with the Google Satellite/Street Background Maps.
> So, I changed the "var authid" in the GlobalOption.js from 3857 to 31467
> (and I also added the missing EPSG31467 record to the libs/proj4js/defs).
> After many attempts, I found that the Background Maps work only when you
> set  var authid="EPSG"+3857 in GlobalOptions.js.
> Consequently I can publish QGIS projects in EPSG31647 after switching
> the "var authid" to EPSG 31467 only if I switch off the Google
> Background Maps (in GlobalOptions.js with var enableBGMaps = false;) at
> the same time.
> Can anybody confirm this?
> Or is there a setting to tell the Background Maps to transform
> automatically into the EPSG given in the "authid" variable?
> Thanks for any comments.
> Markus
> N.B.
> I know, that I could save my QGIS projects in EPSG3857 to publish them
> in QWC together with the Background Maps, but then I am loosing the
> original coordinates and this also leads to some geometrical inaccuracies.
> Dr. Markus Weidenbach
> *landConsult.de*
> Geographical Information Management
> and Environmental Planning
> D-77815 Bühl
> Germany
> e.mail see: http://landConsult.de
__________ Information from ESET Mail Security, version of virus signature database 9997 (20140625) __________
The message was checked by ESET Mail Security.
http://www.eset.com
