[Qgis-user] QWC strange behaviour of Zoom and Pan functions if authid=EPSG31467 and problems with long directory paths in qgis-mapserver
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Jun 27 00:27:13 PDT 2014
 >Is there a limit of characters for paths or shapefile names used in
the QGIS *.qgs file that affects the qgis-mapserver?
Not that I know.
Is it possible that it is a problem with the file permissions for the
webserver user?
Regards,
Marco
On 27.06.2014 09:08, Markus Weidenbach wrote:
> Dear List,
> I am running the QGIS Web Client (checkout from GIT HUB on 25.06.14)
> and QGIS Webserver 2.2.0 on Debian 7.
> In GlobalOptions.js I set the authid variable to 31467 and I am
> publishing only data in that projection ( I also disabled Google Maps
> in GlobalOptions.js).
> Everything works fine, but the ZOOM and the PAN function in QWC behave
> strange, in fact it is almost impossible to zoom or pan to a selected
> spot.
> You can test it yourself on
> http://188.138.88.141/qgis-web-client/site/qgiswebclient.html?map=/home/wbv/Untersuchungsgebiet_GK3_2.qgs
> or
> http://188.138.88.141/qgis-web-client/site/qgiswebclient.html?map=/var/www/qgis-web-client/projects/test_GK3.qgs
> Any idea whats wrong here?
> If I switch the QWC back to EPSG3857 the ZOOM/PAN works normal.
> Another problem I encountered is the fact, that the webserver is not
> reading shapefiles which use a very long directory path.
> e.g. the shape
> /var/www/qgis-web-client/projects/wbv/wbv-geodaten/shape/ugebiet/teilgebiet_nord_1km_kacheln.shp
> is not listet in the GetCapabilities request (see
> http://188.138.88.141/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/var/www/qgis-web-client/projects/Untersuchungsgebiet_GK3.qgs).
> But after copying the same shape to /home/wbv/wbv-geodaten/nord.shp
> (together with the corrected *.qgs) this layer is listet in the
> http://188.138.88.141/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/wbv/Untersuchungsgebiet_GK3_2.qgs)
> and is also displayed in the QWC (see
> http://188.138.88.141/qgis-web-client/site/qgiswebclient.html?map=/home/wbv/Untersuchungsgebiet_GK3_2.qgs).
> Thanks for your comments.
> Markus
> Dr. Markus Weidenbach
> *landConsult.de*
> Geographical Information Management
> and Environmental Planning
> D-77815 Bühl
> Germany
> e.mail see: http://landConsult.de
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140627/d27ddb31/attachment.html>
