[Qgis-user] Time manager 1.1 in QGIS 2.4
G. Garibaldi digitalmaps at cox.net
Sun Jun 29 07:10:11 PDT 2014
Same non-functional result on OSGeo4W installer. TM animation works
properly with shape file data. Looks like the problem is with the
PostgreSQL database connection. Permissions would be my guess.
I'll have to export all my point data to shape files to do animation.
Hey, its free.
The QGIS 2.4 release is fast.
Thanks Anita, everybody.
G.
> Windows 7 64-bit. QGIS standalone installer. Time Manager version 1.1.
> I start a new project, load one vector layer of a PostgreSQL database
> table with point data. PostgreSQL version 9.3, PostGIS version 2.1.
> The data shows on screen. Open TM dialog and select the layer as
> usual. Up to this point everything functions as expected. The screen
> looks normal. When I enable TM the data disappears. I check the time,
> looks OK. Time interval is correct. Opening the attribute table while
> TM is enabled shows no datapoints when I expect one data point. When I
> disable TM all the data reappears.
> Using TM 1.0 enables me to load layers that do function normally,
> however when I save the project, exit and then restart the project
> only one layer shows in the layer list in TM. The other layers don't
> get saved.
> This is an old project that works well enough in QGIS 1.8. with TM
> 0.7. In later versions I can't get TM to function properly.
> I'll try the OSGeo4W installer.
>> Hi,
>> I get the same deprecation warning but it does not affect the
>> functioning of the plugin for me with 2.4 installed using OSGeo4W
>> 64bit installer on Win8.
>> Could you describe a bit more what happens? Is the whole screen blank?
>> Or is just the TimeManager panel blank? Which OS?
>> Best wishes,
>> Anita
>> On Sun, Jun 29, 2014 at 8:22 AM, G. Garibaldi<digitalmaps at cox.net>  wrote:
>>> I can't get TM 1.1 to work in 2.4 64-bit. Load one layer and it doesn't show
>>> anything when TM is enabled - blank screen. Interestingly, TM 1.0 works
>>> somewhat.
>>> Log File:
>>> warning:C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py:844:
>>> PendingDeprecationWarning: This method will be removed in future versions.
>>> Use 'elem.iter()' or 'list(elem.iter())' instead.
>>>    for include in elem.getiterator("include"):
>>> traceback:  File "<string>", line 1, in <module>
>>>    File "C:/PROGRA~1/QGISCH~1/apps/qgis/./python\qgis\utils.py", line 213, in
>>> startPlugin
>>>      plugins[packageName].initGui()
>>>    File
>>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanager.py", line
>>> 44, in initGui
>>>      control.initGui()
>>>    File
>>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagercontrol.py",
>>> line 65, in initGui
>>>      self.guiControl =
>>> TimeManagerGuiControl(self.iface,self.timeLayerManager)
>>>    File
>>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagerguicontrol.py",
>>> line 54, in __init__
>>>      self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
>>>    File
>>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\__init__.py",
>>> line 238, in loadUi
>>>      return DynamicUILoader(package).loadUi(uifile, baseinstance,
>>> resource_suffix)
>>>    File
>>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\Loader\loader.py",
>>> line 71, in loadUi
>>>      return self.parse(filename, resource_suffix, basedir)
>>>    File
>>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py",
>>> line 933, in parse
>>>      actor(elem)
>>>    File
>>> line 844, in readResources
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140629/d792624c/attachment.html>
