[Qgis-user] Symbology Export
Joris HINTJENS jh at enecowindbelgium.com
Mon Mar 10 09:22:57 PDT 2014
I use the plugin GEarthview for KML-KMZ export. It keeps the styling for polygones and attributes
Joris
Hi List,
General curiosity question.
When using "Save Vector Layer as" to save a vector layer, there's an optioon:
"Symbology Export"
This in turn has three options:
"No Symbology"
"Feature symbology"
"Symbol layer symbology"
What does this do? I've tried exporting to both KML and TAB files using these options but they don't appear to keep the symbology.
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140310/15c9d622/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140310/15c9d622/attachment.txt>
