[Qgis-user] QGIs crashes opening old (2.0.1) projects in valmiera (2.2.1)
Andre Joost
andre+joost at nurfuerspam.de
Fri Mar 14 08:08:29 PDT 2014
Hi Alexandre,
the reduced project file refers to
file="//fileserver/PUBLIC/SIG DTOP/Cascais Ambiente - logo externo.jpg".
Can you substitute that to a local file to see if the composer does not
like that?
HTH,
André Joost
Am 14.03.2014 11:20, schrieb Alexandre Neto:
> Victor,
> Thank you very much for your effort. I started that process at home, with a
> ubuntu instalation and I was not able to complete it.
> Meanwhile I have opended a ticket:
> https://hub.qgis.org/issues/9779
> I am going to try recreate a project with the same problem but with less
> layers, in order to reduce the pain of trying to open it, and make testing
> a bit more fast.
> Thanks again,
> Alexandre
> On Thu, Mar 13, 2014 at 12:27 PM, Víctor Manuel Herreros Villanueva<
> vherreros at ucm.es> wrote:
>> Alexander,
>> I've tried to open it under QGIS Valmiera, Windows 7 64 bit.
>> I've had to click 'Cancel' for all of your layers database connections
>> (cause I don't have your tables in my PostgreSQL Server) - patiently
>> waiting more or less 30 seconds until my server time outs for each of your
>> 22 tables.
>> Then I got a 'missing file' error in QGIS (cause I don't have
>> '//Fileserver/PRIVATE/Ortos/ORTOS2013/ortos2013.vrt' file on my
>> filesystem). QGIS told me this layer would be lost, and I agreed.
>> The I got a minidump, whose contents are inside the file uploaded here<http://www.mediafire.com/download/51qjs8257a63n6n/qgis-20140313-131106-4984-2232-c3a2817.dmp>,
>> in case you want it for opening the ticket.
>> And finally, QGIS closed.
>> So I've not been able to open it.
>> Sorry...
>> 2014-03-13 12:52 GMT+01:00 Alexandre Neto<senhor.neto at gmail.com>:
>> Hello Ariel,
>>> Even in new installations the project fails to open and crashes.
>>> As a workaround, I was able to open a new blank project, and add all
>>> layer groups using embed
>>> layer and groups... and recreate part of the project, But all print
>>> composers are lost, and probably other stuff that I'm not aware of now.
>>> I think I will open a ticket for this, and do some more testings.
>>> Thanks for your answer,
>>> Alexandre
>>> On Thu, Mar 13, 2014 at 8:21 AM, Rodriguez, A.<arielrod24 at gmail.com>wrote:
>>>> Alexander:
>>>> Try to uninstall and re-install the software.
>>>> Greetings and good luck.
>>>> Ariel
>>>> On 12/03/14 17:27, Alexandre Neto wrote:
>>>> Hello,
>>>> I'm having problems opening a Dufour project (2.0.1) in Valmiera
>>>> (2.2.1) using windows 7 64 bit.
>>>> QGIS warns me that a older version project is going to be opened, but
>>>> crashes during the reading of the layers. The same file still opens in
>>>> 2.0.1 without problems.
>>>> Is there any known issues of lower versions compatibility? Any
>>>> workarounds?
>>>> The problematic project is the following:
>>>> https://dl.dropboxusercontent.com/u/110618644/SIG_DTOP.qgs
>>>> Thanks,
>>>> Alexandre Neto
>>>> _______________________________________________
>>>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>> <http://www.ucm.es/> *Universidad Complutense de Madrid*<http://www.ucm.es/> *Víctor
>> Manuel Herreros Villanueva*, PhD.
>> Project Manager
>> *Facilities ManagementData Warehouse*
>> Jardín Botánico
>> Av. Complutense s/n
>> 28040 Madrid
>> Spain
>> *Phn. no. (+34) 91 394 7275Fax no. (+34) 91 394 4773* vherreros at ucm.es
