[Qgis-user] QGIs crashes opening old (2.0.1) projects in valmiera (2.2.1)
Alexandre Neto senhor.neto at gmail.com
Fri Mar 14 09:15:28 PDT 2014
Hello all,
Thank you for your help.
I seemed that an empty name for the atlas coverage layer in the project was
the causing the problems.
I reported all in the ticket: https://hub.qgis.org/issues/9779
And it seems to have been solved already. Great job Jürgen Fischer!
Alexandre Neto
On Fri, Mar 14, 2014 at 3:08 PM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Hi Alexandre,
> the reduced project file refers to
> file="//fileserver/PUBLIC/SIG DTOP/Cascais Ambiente - logo externo.jpg".
> Can you substitute that to a local file to see if the composer does not
> like that?
> HTH,
> André Joost
> Am 14.03.2014 11:20, schrieb Alexandre Neto:
>> Victor,
>> Thank you very much for your effort. I started that process at home, with
>> a
>> ubuntu instalation and I was not able to complete it.
>> Meanwhile I have opended a ticket:
>> I am going to try recreate a project with the same problem but with less
>> layers, in order to reduce the pain of trying to open it, and make testing
>> a bit more fast.
>> Thanks again,
>> Alexandre
>> On Thu, Mar 13, 2014 at 12:27 PM, Víctor Manuel Herreros Villanueva<
>> vherreros at ucm.es>  wrote:
>>  Alexander,
>>> I've tried to open it under QGIS Valmiera, Windows 7 64 bit.
>>> I've had to click 'Cancel' for all of your layers database connections
>>> (cause I don't have your tables in my PostgreSQL Server) - patiently
>>> waiting more or less 30 seconds until my server time outs for each of
>>> your
>>> 22 tables.
>>> Then I got a 'missing file' error in QGIS (cause I don't have
>>> '//Fileserver/PRIVATE/Ortos/ORTOS2013/ortos2013.vrt' file on my
>>> filesystem). QGIS told me this layer would be lost, and I agreed.
>>> The I got a minidump, whose contents are inside the file uploaded here<
>>> http://www.mediafire.com/download/51qjs8257a63n6n/qgis-
>>> 20140313-131106-4984-2232-c3a2817.dmp>,
>>> in case you want it for opening the ticket.
>>> And finally, QGIS closed.
>>> So I've not been able to open it.
>>> Sorry...
>>> 2014-03-13 12:52 GMT+01:00 Alexandre Neto<senhor.neto at gmail.com>:
>>> Hello Ariel,
>>>> Even in new installations the project fails to open and crashes.
>>>> As a workaround, I was able to open a new blank project, and add all
>>>> layer groups using embed
>>>> layer and groups...  and recreate part of the project, But all print
>>>> composers are lost, and probably other stuff that I'm not aware of now.
>>>> I think I will open a ticket for this, and do some more testings.
>>>> Thanks for your answer,
>>>> Alexandre
>>>> On Thu, Mar 13, 2014 at 8:21 AM, Rodriguez, A.<arielrod24 at gmail.com
>>>> >wrote:
>>>>    Alexander:
>>>>> Try to uninstall and re-install the software.
>>>>> Greetings and good luck.
>>>>> Ariel
>>>>> On 12/03/14 17:27, Alexandre Neto wrote:
>>>>>   Hello,
>>>>>   I'm having problems opening a Dufour project (2.0.1) in Valmiera
>>>>> (2.2.1) using windows 7 64 bit.
>>>>>   QGIS warns me that a older version project is going to be opened, but
>>>>> crashes during the reading of the layers. The same file still opens in
>>>>> 2.0.1 without problems.
>>>>>   Is there any known issues of lower versions compatibility? Any
>>>>> workarounds?
>>>>>   The problematic project is the following:
>>>>>   https://dl.dropboxusercontent.com/u/110618644/SIG_DTOP.qgs
>>>>>   Thanks,
>>>>>   Alexandre Neto
>>>>> _______________________________________________
>>>>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/
>>>>> mailman/listinfo/qgis-user
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>    <http://www.ucm.es/>  *Universidad Complutense de Madrid*<
>>> http://www.ucm.es/>   *Víctor
>>> Manuel Herreros Villanueva*, PhD.
>>> Project Manager
>>> *Facilities ManagementData Warehouse*
>>>   Jardín Botánico
>>> Av. Complutense s/n
>>> 28040 Madrid
>>> Spain
>>> *Phn. no. (+34) 91 394 7275Fax no.  (+34) 91 394 4773*  vherreros at ucm.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140314/419dfff4/attachment.html>
