[Qgis-user] Am I out of luck?
Marcel Stadelmann
marcel.stadelmann at gmx.net
Thu May 1 11:21:38 PDT 2014
When I deactivate GRASS in the Plugin Manager then QGIS 2.0.1 is not able to open anymore the (old) Project File (QGiS is crashing). When I activate GRASS again QGIS opens the Project without errors. Mac OSX 10.8.5
Regards
Marcel
Am 29.04.2014 um 20:17 schrieb Alex Mandel <tech_dev at wildintellect.com>:
> On 04/29/2014 11:14 AM, Ross Easterling wrote:
>> I'm getting this error:
>> UNABLE TO OPEN PROJECT:
>> Project file read error: unexpected end of file at line 1 column 1 for file C:/aross/OZ/GIS/state str.qgs
>> Am I just out of luck?
> Open the .qgs file in a text editor to see what might be wrong
> (Notepad++ is a good option on Windows). You are not out of luck it's an
> XML format text file. Though if the file is empty you'll need to go look
> for a backup.
> Compare against a new project file to see how it should look.
> Thanks,
> Alex
> Qgis-user mailing list
