[Qgis-user] zmap plus default format, gdal qgis
Matt Boyd mattslists at gmail.com
Sun May 4 17:43:46 PDT 2014
Hi QGIS users,
I've often used zmap plus as a format to transfer between different
software in the past. I'm unable to get this to work in 2.2. I either get
an import / file not supported error or I get a layer that loads but shows
values wildly different (ie values should be 1000 and I see 1.234e-308) to
the ones that should be in the raster.
Has anyone else had this issue? I initially thought it was an error with
the software I was exporting from. I haven't had time to hunt down logs,
but I've looked at the headers and they look fine. Is there anything
obvious or some recent bugs I'm not aware of?
Thanks
Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140505/5f229227/attachment.html>
