[Qgis-user] zmap plus default format, gdal qgis
Alex Mandel tech_dev at wildintellect.com
Sun May 4 18:24:20 PDT 2014
On 05/04/2014 05:43 PM, Matt Boyd wrote:
> Hi QGIS users,
> I've often used zmap plus as a format to transfer between different
> software in the past. I'm unable to get this to work in 2.2. I either get
> an import / file not supported error or I get a layer that loads but shows
> values wildly different (ie values should be 1000 and I see 1.234e-308) to
> the ones that should be in the raster.
> Has anyone else had this issue? I initially thought it was an error with
> the software I was exporting from. I haven't had time to hunt down logs,
> but I've looked at the headers and they look fine. Is there anything
> obvious or some recent bugs I'm not aware of?
> Thanks
> Matt
Are you saying it was working in QGIS previously?
You can always use the Raster menu GDAL Translate
http://gdal.org/frmt_various.html#ZMap
Enjoy,
Alex
