[Qgis-user] zmap plus default format, gdal qgis
Matt Boyd mattslists at gmail.com
Sun May 4 19:19:03 PDT 2014
GDAL gives an error, looks like it's something with that.
Yes, it was working in qgis previously.
Matt
On Mon, May 5, 2014 at 11:24 AM, Alex Mandel <tech_dev at wildintellect.com>wrote:
> On 05/04/2014 05:43 PM, Matt Boyd wrote:
> > Hi QGIS users,
> > I've often used zmap plus as a format to transfer between different
> > software in the past. I'm unable to get this to work in 2.2. I either get
> > an import / file not supported error or I get a layer that loads but
> shows
> > values wildly different (ie values should be 1000 and I see 1.234e-308)
> to
> > the ones that should be in the raster.
> > Has anyone else had this issue? I initially thought it was an error with
> > the software I was exporting from. I haven't had time to hunt down logs,
> > but I've looked at the headers and they look fine. Is there anything
> > obvious or some recent bugs I'm not aware of?
> > Thanks
> > Matt
> Are you saying it was working in QGIS previously?
> You can always use the Raster menu GDAL Translate
> http://gdal.org/frmt_various.html#ZMap
> Enjoy,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140505/023a5704/attachment.html>
