[Qgis-user] Ubuntu 14.04 and qgis
Randal Hale rjhale at northrivergeographic.com
Mon May 5 09:16:44 PDT 2014
Mine was actually working quite well before the message about upgrading.
I did the upgrade on a test machine - so my main workstation is working
happily along. I'm actually using it now to finish up one forestry project.
As far as Operating systems - Try Xubuntu. It's a lot less resource
heavy and that's what I've been running for several years and am quite
happy with it. I tend to drift about once a year and trying something
different but come back to it after a while. Unity (while enticing) is
uses way to much memory for my inner happiness.
It almost sounds like an operating system issue vs QGIS.....or there is
some corruption or something happening during the install. I assume
since you are using NTFS you are dual booting? Or I guess I should say
dual partitions?
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
http://about.me/rjhale
On 05/05/2014 12:03 PM, Lens Paul wrote:
> Hi Randy,
> Your message came when I was about to send a message explaining my
> problems.
> Using QGIS 2.2+Grass on Ubuntu 14.04 LTS, installed in accordance with
> the instructions given on the "alldownloads.html" page on qis.org.
> At first, it worked very well. QGIS could even open a project file
> which didn't  open on another computer.
> After several boots,  Ubuntu began to display an internal error
> message, than it hanged on next reboot, displaying "running in low
> graphics mode" (the graphic card is in the chipset: "Intel(R) 82945G
> Express Chipset Family").
> After reinstallation of Ubuntu and QGIS, QGIS 2.2 opened the project
> file but could not load the layers.
> In fact, it adds "1" to the partition name (in this case the NTFS
> partition named "R3SERVE" becomes "R3SERVE1") and whence it doesn't
> recognise the path. A weird behaviour since Ubuntu still displays the
> correct name "R3SERVE"!
> Here is a sample (I deleted several lines) of the messages displayed
> in "Terminal":
> plfixe2 at plfixe2-Dimension-5100:~$ qgis
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> Warning: void DBusMenuExporterPrivate::addAction(QAction*, int):
> Already tracking action "Toolbox" under id 255
> (qgis.bin:4353): Gtk-WARNING **: Attempting to read the recently used
> resources file at `/home/plfixe2/.local/share/recently-used.xbel', but
> the parser failed: L'ouverture du fichier «
> /home/plfixe2/.local/share/recently-used.xbel » a échoué : Permission
> non accordée.
> ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'.
> ERROR 4:
> `/media/plfixe2/R2SERVE/SIG_proj/MB103_Ille/Donnees/00-general/4_PPNC/68_68_w.jpg'
> does not exist in the file system,
> and is not recognised as a supported dataset name.
> ERROR 6: EPSG PCS/GCS code 103300 not found in EPSG support files.  Is
> this a valid
> EPSG coordinate system?
> Warning: Couldn't open the data source:
> /media/plfixe2/R2SERVE/SIG_proj/MB103_Ille/Donnees/00-general/GPS/AOU-11-11
> 053928 PM.gpx
> Besides after reboot, Ubuntu displays again an internal error
> problem.  I suppose it is going to hang again on the next reboots.
> Hope this helps,
> Paul
> Le 5/05/2014 15:38, Randal Hale a écrit :
>> For those of you on Ubuntu 14.04 running qgis from the repo: deb
>> http://qgis.org/debian trusty main - you will be getting an upgrade
>> notice from the software update application (ubuntu and xubuntu) on
>> upgrading qgis. I would hold off just a bit - I upgraded and there
>> are some compatibilities issues that kill your install of qgis.
>> Randy
> Qgis-user mailing list
