[Qgis-user] Qgis-user Digest, Vol 99, Issue 6
Joshua Amend
joshuaamend at gmail.com
Mon May 5 12:33:56 PDT 2014
Sure. Kids just got home and reminded me this week is the book fair, and there's no school Friday.
> On May 5, 2014, at 3:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Ubuntu 14.04 and qgis (Randal Hale)
> 2. Re: Ubuntu 14.04 and qgis (Lens Paul)
> 3. Re: Ubuntu 14.04 and qgis (Randal Hale)
> 4. Qgis Python Error when using openlayers plugin and some
> others (slackve)
> 5. Qgis gets wrong postgis field as id (Estevan Barbar?)
> 6. Re: Qgis Python Error when using openlayers plugin and some
> others (Gino Pirelli)
> 7. Re: Qgis gets wrong postgis field as id (Alexandre Neto)
> 8. Re: Qgis Python Error when using openlayers plugin and some
> others (slackve)
> 9. processing upgrade broken (Kurt Trinko)
> Message: 1
> Date: Mon, 05 May 2014 09:38:52 -0400
> From: Randal Hale <rjhale at northrivergeographic.com>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Ubuntu 14.04 and qgis
> Message-ID: <5367946C.4040403 at northrivergeographic.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> For those of you on Ubuntu 14.04 running qgis from the repo: deb
> http://qgis.org/debian trusty main - you will be getting an upgrade
> notice from the software update application (ubuntu and xubuntu) on
> upgrading qgis. I would hold off just a bit - I upgraded and there are
> some compatibilities issues that kill your install of qgis.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale
> http://about.me/rjhale
> Message: 2
> Date: Mon, 05 May 2014 18:03:15 +0200
> From: Lens Paul <paul.lens at gmx.com>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Ubuntu 14.04 and qgis
> Message-ID: <5367B643.4030208 at gmx.com>
> Hi Randy,
> Your message came when I was about to send a message explaining my problems.
> Using QGIS 2.2+Grass on Ubuntu 14.04 LTS, installed in accordance with
> the instructions given on the "alldownloads.html" page on qis.org.
> At first, it worked very well. QGIS could even open a project file which
> didn't open on another computer.
> After several boots, Ubuntu began to display an internal error message,
> than it hanged on next reboot, displaying "running in low graphics mode"
> (the graphic card is in the chipset: "Intel(R) 82945G Express Chipset
> Family").
> After reinstallation of Ubuntu and QGIS, QGIS 2.2 opened the project
> file but could not load the layers.
> In fact, it adds "1" to the partition name (in this case the NTFS
> partition named "R3SERVE" becomes "R3SERVE1") and whence it doesn't
> recognise the path. A weird behaviour since Ubuntu still displays the
> correct name "R3SERVE"!
> Here is a sample (I deleted several lines) of the messages displayed in
> "Terminal":
> plfixe2 at plfixe2-Dimension-5100:~$ qgis
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
> tracking action "Toolbox" under id 255
> (qgis.bin:4353): Gtk-WARNING **: Attempting to read the recently used
> resources file at `/home/plfixe2/.local/share/recently-used.xbel', but
> the parser failed: L'ouverture du fichier
> ? /home/plfixe2/.local/share/recently-used.xbel ? a ?chou? : Permission
> non accord?e.
> ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'.
> ERROR 4:
> `/media/plfixe2/R2SERVE/SIG_proj/MB103_Ille/Donnees/00-general/4_PPNC/68_68_w.jpg'
> does not exist in the file system,
> and is not recognised as a supported dataset name.
> ERROR 6: EPSG PCS/GCS code 103300 not found in EPSG support files. Is
> this a valid
> EPSG coordinate system?
> Warning: Couldn't open the data source:
> /media/plfixe2/R2SERVE/SIG_proj/MB103_Ille/Donnees/00-general/GPS/AOU-11-11
> 053928 PM.gpx
> Besides after reboot, Ubuntu displays again an internal error problem.
> I suppose it is going to hang again on the next reboots.
> Hope this helps,
> Paul
> Le 5/05/2014 15:38, Randal Hale a ?crit :
>> Randy
> Message: 3
> Date: Mon, 05 May 2014 12:16:44 -0400
> Message-ID: <5367B96C.9070003 at northrivergeographic.com>
> Mine was actually working quite well before the message about upgrading.
> I did the upgrade on a test machine - so my main workstation is working
> happily along. I'm actually using it now to finish up one forestry project.
> As far as Operating systems - Try Xubuntu. It's a lot less resource
> heavy and that's what I've been running for several years and am quite
> happy with it. I tend to drift about once a year and trying something
> different but come back to it after a while. Unity (while enticing) is
> uses way to much memory for my inner happiness.
> It almost sounds like an operating system issue vs QGIS.....or there is
> some corruption or something happening during the install. I assume
> since you are using NTFS you are dual booting? Or I guess I should say
> dual partitions?
> Randy
> Randal Hale, GISP
> twitter:rjhale
>> On 05/05/2014 12:03 PM, Lens Paul wrote:
>> Hi Randy,
>> problems.
>> which didn't open on another computer.
>> message, than it hanged on next reboot, displaying "running in low
>> graphics mode" (the graphic card is in the chipset: "Intel(R) 82945G
>> Express Chipset Family").
>> in "Terminal":
>> Already tracking action "Toolbox" under id 255
>> the parser failed: L'ouverture du fichier ?
>> non accord?e.
>> ERROR 4:
>> this a valid
>> 053928 PM.gpx
>> problem. I suppose it is going to hang again on the next reboots.
>> Hope this helps,
>> Paul
>>> are some compatibilities issues that kill your install of qgis.
>>> Randy
> Message: 4
> Date: Mon, 5 May 2014 09:18:44 -0700 (PDT)
> From: slackve <alejandrogomez84 at gmail.com>
> Subject: [Qgis-user] Qgis Python Error when using openlayers plugin
> and some others
> Message-ID: <1399306724817-5138648.post at n6.nabble.com>
> Content-Type: text/plain; charset=UTF-8
> Greetings.
> I get this error when trying to use openlayers plugin and some others
> like "RT Mapserver Export"
> Ha ocurrido un error mientras se ejecutaba el c?digo de Python:
> Traceback (most recent call last):
> File "/root/.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py",
> line 50, in addLayer
> self.__plugin.addLayer(self)
> line 202, in addLayer
> self.__setMapSrsGoogle()
> line 253, in __setMapSrsGoogle
> mapCanvas.mapRenderer().setProjectionsEnabled(True)
> TypeError: C++ type 'const QgsMapLayer*' is not supported as type
> Versi?n de Python:
> 2.7.5 (default, Apr 29 2014, 10:23:44)
> [GCC 4.8.2]
> Versi?n de QGIS:
> 2.2.0-Valmiera Valmiera, exported
> Ruta de Python: ['/root/.qgis2/python/plugins/processing',
> '/usr/share/qgis/python', u'/root/.qgis2/python',
> u'/root/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.7/site-packages/openerp-7.0_20130716_231027-py2.7.egg',
> '/usr/lib/python2.7/site-packages/Werkzeug-0.10_devdev_20130717-py2.7.egg',
> '/usr/lib/python2.7/site-packages/vatnumber-1.1-py2.7.egg',
> '/usr/lib/python2.7/site-packages/unittest2-0.5.1-py2.7.egg',
> '/usr/lib/python2.7/site-packages/PyWebDAV-0.9.8-py2.7.egg',
> '/usr/lib/python2.7/site-packages/python_ldap-2.4.13-py2.7-linux-i686.egg',
> '/usr/lib/python2.7/site-packages/python_dateutil-1.5-py2.7.egg',
> '/usr/lib/python27.zip', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/lib/python2.7/site-packages',
> '/usr/lib/python2.7/site-packages/PIL',
> '/usr/lib/python2.7/site-packages/gtk-2.0',
> '/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode',
> '/usr/share/qgis/python/plugins/fTools/tools']
> This happened after I upgraded from Slackware 14.0 to 14.1, I
> recompiled Qgis and its dependencies again just in case but still
> gives me the same error
> I appreciate any help you can provide
> Thank you.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-Python-Error-when-using-openlayers-plugin-and-some-others-tp5138648.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Message: 5
> Date: Mon, 5 May 2014 13:33:27 -0300
> From: Estevan Barbar? <estevan.barbara at gmail.com>
> Subject: [Qgis-user] Qgis gets wrong postgis field as id
> Message-ID:
> <CAERb0eok2cDWBumRvNAe8bvtnxmHGG6pHdvQkOcJg0SEetv2vQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello folks
> I'm adding some views to a project and one of them returns the error "is an
> invalid layer".
> The log shows that instead of the id field, it is getting line_id as key, a
> not unique integer.
> Is there some way to fix it?
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140505/78b223b8/attachment-0001.html>
> Message: 6
> Date: Mon, 5 May 2014 19:53:44 +0200
> From: Gino Pirelli <luipir at gmail.com>
> To: slackve <alejandrogomez84 at gmail.com>
> Cc: qgis-user ML <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Qgis Python Error when using openlayers
> Message-ID:
> <CAFO80_qQ+09bp6c=xXjq2OZhutZJV_zLQjAHwodq5F4JhPF7aw at mail.gmail.com>
> I'm the mantainer of the "RT mapserver exporter" plugin, can you open e
> ticket with detailed description of the error?
> thank you
> Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
>> On 5 May 2014 18:18, slackve <alejandrogomez84 at gmail.com> wrote:
>> Greetings.
>> File
>> File
>> File
>> Versi?n de Python:
>> [GCC 4.8.2]
>> Versi?n de QGIS:
>> Thank you.
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140505/00ca219b/attachment-0001.html>
> Message: 7
> Date: Mon, 5 May 2014 19:17:01 +0100
> From: Alexandre Neto <senhor.neto at gmail.com>
> To: Estevan Barbar? <estevan.barbara at gmail.com>
> Cc: QGIS User <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Qgis gets wrong postgis field as id
> Message-ID:
> <CA+H0G_HhpqL2YeZpuAb+N5X757L-_fGD0WHfuDOzFH0qd_AzMw at mail.gmail.com>
> Hello Estevan,
> This was already reported here:
> https://hub.qgis.org/issues/9803
> You can fix this by setting the primary key field in the add postgis Layer
> Dialog.
> Hope this helps
> On Mon, May 5, 2014 at 5:33 PM, Estevan Barbar?
> <estevan.barbara at gmail.com>wrote:
>> Hello folks
>> an invalid layer".
>> a not unique integer.
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140505/9cc78670/attachment-0001.html>
> Message: 8
> Date: Mon, 5 May 2014 11:25:50 -0700 (PDT)
> Message-ID: <1399314350051-5138667.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Sure but where do I do that ?
> Over here on nabble or http://hub.qgis.org/projects/rtmapserverexporter
> I can't figure out how to open a ticket there on redmine
> Thanks
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-Python-Error-when-using-openlayers-plugin-and-some-others-tp5137970p5138667.html
> Message: 9
> Date: Mon, 5 May 2014 20:42:06 +0200
> From: Kurt Trinko <ktrinko at gmail.com>
> Subject: [Qgis-user] processing upgrade broken
> Message-ID:
> <CADkWe2-tWysOc31FL88zhJFQ8zYozRD_2177VbfDwjkOOWPDig at mail.gmail.com>
> upgraded processing on win 7 64 bit has broken the plugin
> no module named qgis.QGISAlgorithmProvider
> anyone else with this problem?
> kurt
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140505/102d3b62/attachment-0001.html>
> End of Qgis-user Digest, Vol 99, Issue 6
