[Qgis-user] raster toolbar issue
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Tue May 6 03:16:14 PDT 2014
Hi Sam,
To enable the toolbar, from the main menu, View > Toolbars > Raster
What "render type" are you using for your raster? The raster toolbar only works with "Singleband gray".
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
www.lutraconsulting.co.uk
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Sam Marginson
Sent: 06 May 2014 04:25
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] raster toolbar issue
Hi, I’m new here.  Go easy on me please!
One of the features that I like about ArcMap is that you can set it up so that rasters change their symbology based on your view extent.  I’m trying to set QGIS up to do the same thing but having some issues.  I can do it through the raster properties but not the toolbar.
When I press the “Local Histogram Stretch” button, nothing happens.  But then again, none of the buttons on the toolbar seem to work, so I’m wondering if there’s a bigger problem here.  When I right-click on the raster in the Layers window & hit "Stretch Using Current Extent" nothing happens either, so I'm wondering whether it's looking for something that's not there.
Like I mentioned, I have ArcMap, so I'm wondering whether I have the wrong version of Python for QGIS, or if there's some other programming issue at play, like a missing library or something.
Any help would be greatly appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/raster-toolbar-issue-tp5138726.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
