[Qgis-user] Error running QGis on Ubuntu 14.04
dave.potts at pinan.co.uk
Wed May 7 03:24:05 PDT 2014
I built my copy from the source, is there an proper version for Ubuntu 14.04?
> Hi Louis,
> not sure, but maybe related to this post
> http://osgeo-org.1560.x6.nabble.com/Ubuntu-14-04-and-qgis-td5138591.html ?
> Are you sure you have python-qgis and python-qgis-common installed?
> Stefan
> On 05/07/2014 04:36 PM, LuÃs de Sousa [via OSGeo.org] wrote:
>> I have installed QGis on Ubuntu 14.04 from the QGis stable repository
>> [1]; it went fine with no errors reported. But when I launch QGis I
>> get a huge window with the following message:
>> Couldn't load PyQGIS.
>> Python support will be disabled.
>> Traceback (most recent call last):
>> File "", line 1, in
>> File "/usr/lib/python2.7/dist-packages/qgis/init.py", line 35, in
>> from qgis.core import QgsFeature, QgsGeometry
>> ImportError: /usr/lib/python2.7/dist-packages/qgis/core.so:
>> undefined symbol: _ZN16QgsComposerShape12setSceneRectERK6QRectF
>> Python version:
>> 2.7.6 (default, Mar 22 2014, 23:03:41) [GCC 4.8.2]
>> QGIS version:
>> 2.2.0-Valmiera 'Valmiera', exported
>> Python path:
>> ['/usr/share/qgis/python', u'/home/desousa/.qgis2/python',
>> u'/home/desousa/.qgis2/python/plugins',
>> '/usr/share/qgis/python/plugins',
>> '/usr/local/lib/python2.7/dist-packages/MapScript-6.0.1-py2.7-linux-x86_64.egg',
>> '/usr/local/lib/python2.7/dist-packages/virtualenv-1.8.4-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/pip-1.2.1-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/pytz-2012j-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/python_dateutil-2.1-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/six-1.3.0-py2.7.egg',
>> '/usr/lib/grass64/etc/python/grass/script', '/usr/lib/grass64/etc',
>> '/usr/lib/grass64/etc/python', '/usr/lib/grass64/lib',
>> '/usr/lib/grass64/bin', '/usr/lib/grass64/scripts',
>> '/usr/lib/python2.6', '/home/desousa/Eclipse/Workspace.Tudor/OWSLib',
>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/PILcompat',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.7',
>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>> The packages I have installed:
>> $ dpkg -l | grep qgis
>> ii libqgis2.2.0 2.2.0-1~precise1
>> amd64 QGIS - shared libraries
>> ii python-qgis 2.2.0-3+trusty1
>> amd64 Python bindings to QGIS
>> ii python-qgis-common
>> 2.2.0-3+trusty1 all Python
>> bindings to QGIS - architecture-independent files
>> ii qgis 2.2.0-3+trusty1 amd64
>> Geographic Information System (GIS)
>> ii qgis-common 2.2.0-3+trusty1
>> all QGIS - architecture-independent data
>> ii qgis-plugin-globe
>> 2.2.0-3+trusty1 amd64 OSG globe
>> plugin for QGIS
>> ii qgis-plugin-globe-common
>> 2.2.0-3+trusty1 all OSG GLOBE
>> plugin for QGIS - architecture-independent data
>> ii qgis-plugin-grass
>> 2.2.0-3+trusty1 amd64 GRASS plugin
>> for QGIS
>> ii qgis-plugin-grass-common
>> 2.2.0-3+trusty1 all GRASS plugin
>> ii qgis-providers 2.2.0-3+trusty1
>> amd64 collection of data providers to QGIS
>> ii qgis-providers-common
>> 2.2.0-3+trusty1 all collection of
>> data providers to QGIS - architecture-independent files
>> Thank you.
>> [1] http://qgis.org/en/site/forusers/alldownloads.html#ubuntu
>> Qgis-user mailing list
>> [hidden email] </user/SendEmail.jtp?type=node&node=5138956&i=0>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Error-running-QGis-on-Ubuntu-14-04-tp5138956.html
>> To unsubscribe from Quantum GIS - User, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=c3RlZmFuc3lsbGFAZ214LmRlfDQxMjUyNjd8LTExNTE4ODczMTc=>.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> http://osgeo-org.1560.x6.nabble.com/Error-running-QGis-on-Ubuntu-14-04-tp5138956p5138963.html
> Sent from the Quantum GIS - User mailing list archive at
> Nabble.com._______________________________________________
