[Qgis-user] Error running QGis on Ubuntu 14.04
Luís de Sousa luis.a.de.sousa at gmail.com
Wed May 7 05:13:02 PDT 2014
I had to purge the libqgis2.2.0 package and re-install QGis; as you can see
in the original message it as marked as precise. After that all went fine.
Luís
On 7 May 2014 11:34, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
> I have installed QGis on Ubuntu 14.04 from the QGis stable repository [1];
> it went fine with no errors reported. But when I launch QGis I get a huge
> window with the following message:
>     Couldn't load PyQGIS.
>     Python support will be disabled.
>     Traceback (most recent call last):
>     File "", line 1, in
>     File "/usr/lib/python2.7/dist-packages/qgis/init.py", line 35, in
>     from qgis.core import QgsFeature, QgsGeometry
>     ImportError: /usr/lib/python2.7/dist-packages/qgis/core.so: undefined
> symbol: _ZN16QgsComposerShape12setSceneRectERK6QRectF
>     Python version:
>     2.7.6 (default, Mar 22 2014, 23:03:41) [GCC 4.8.2]
>     QGIS version:
>     2.2.0-Valmiera 'Valmiera', exported
>     Python path:
>     ['/usr/share/qgis/python', u'/home/desousa/.qgis2/python',
> u'/home/desousa/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/local/lib/python2.7/dist-packages/MapScript-6.0.1-py2.7-linux-x86_64.egg',
> '/usr/local/lib/python2.7/dist-packages/virtualenv-1.8.4-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/pip-1.2.1-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/pytz-2012j-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/python_dateutil-2.1-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/six-1.3.0-py2.7.egg',
> '/usr/lib/grass64/etc/python/grass/script', '/usr/lib/grass64/etc',
> '/usr/lib/grass64/etc/python', '/usr/lib/grass64/lib',
> '/usr/lib/grass64/bin', '/usr/lib/grass64/scripts', '/usr/lib/python2.6',
> '/home/desousa/Eclipse/Workspace.Tudor/OWSLib', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
> The packages I have installed:
> $ dpkg -l | grep qgis
> ii  libqgis2.2.0
> 2.2.0-1~precise1                                    amd64        QGIS -
> shared libraries
> ii  python-qgis
> 2.2.0-3+trusty1                                     amd64        Python
> bindings to QGIS
> ii  python-qgis-common
> 2.2.0-3+trusty1                                     all          Python
> bindings to QGIS - architecture-independent files
> ii  qgis
> 2.2.0-3+trusty1                                     amd64        Geographic
> Information System (GIS)
> ii  qgis-common
> 2.2.0-3+trusty1                                     all          QGIS -
> architecture-independent data
> ii  qgis-plugin-globe
> 2.2.0-3+trusty1                                     amd64        OSG globe
> plugin for QGIS
> ii  qgis-plugin-globe-common
> 2.2.0-3+trusty1                                     all          OSG GLOBE
> plugin for QGIS - architecture-independent data
> ii  qgis-plugin-grass
> 2.2.0-3+trusty1                                     amd64        GRASS
> plugin for QGIS
> ii  qgis-plugin-grass-common
> 2.2.0-3+trusty1                                     all          GRASS
> ii  qgis-providers
> 2.2.0-3+trusty1                                     amd64        collection
> of data providers to QGIS
> ii  qgis-providers-common
> 2.2.0-3+trusty1                                     all          collection
> of data providers to QGIS - architecture-independent files
> Thank you.
> [1] http://qgis.org/en/site/forusers/alldownloads.html#ubuntu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140507/9ce7e2ca/attachment.html>
