[Qgis-user] Projection String
Even Rouault
even.rouault at mines-paris.org
Thu May 8 03:03:47 PDT 2014
> The *+b *is the semi-minor axis right? If so, the values 298 is I think
> weird.
298.xxx is a typical value for the reverse flattening, not the semi-minor axis.
So you should use +rf instead of +b
But as those values are in fact the definition of the WGS84 ellipsoid, you
could more simply replace the "+a=xxxx +rf=xxxx" by +ellps=WGS84
Geospatial professional services
http://even.rouault.free.fr/services.html
