[Qgis-user] Visual range selector to filter property values
Tobias Preuss
tobias.preuss+osgeo at googlemail.com
Fri May 9 12:24:06 PDT 2014
Thank you Luigi. That might be a good starting point.
I never developed for QGIS before. Can you point me to some good
introduction material for QWebView and related topics?
On Fri, May 9, 2014 at 8:22 AM, Gino Pirelli <luipir at gmail.com> wrote:
> I don't know if there are plugins about your proposal... but it is simple to
> integrate in qgis wrapping good JS libraries inside a QWebView and
> interacting with qgis using slots and injection
> I did a technical presentation to summarize this integration way
> slides.com/ginopirelli/qgis_linking_js_with_python
> ciao Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
> On 8 May 2014 18:09, Tobias Preuss <tobias.preuss+osgeo at googlemail.com>
> wrote:
>> Hello.
>> I was working with a data set the other day which has a few properties
>> where values spread along a certain range.
>> An easy example would be age of people.
>> Then I stumble into some libraries [1, 2] which provide a visual range
>> selector (see attached screeshot) to filter these values.
>> This allows to grab a certain window within the data property.
>> Is there anything like this for QGIS? A plug-in maybe?
>> Thanks for comments, Tobias
>> ____
>> [1] http://square.github.io/crossfilter/
>> [2] http://dygraphs.com/gallery/#g/range-selector
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
