[Qgis-user] Problem with WMS in QGIS 2.2
Bruce, Bob (CWS) Bob.Bruce at gov.mb.ca
Wed May 14 11:50:00 PDT 2014
Richard,
             thanks so much. It works great.
Bob Bruce
________________________________________
From: Richard Duivenvoorde [rdmailings at duif.net]
Sent: May 14, 2014 1:14 PM
To: Bruce, Bob (CWS); Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Problem with WMS in QGIS 2.2
Hi Bob,
Looking into to he capabilities of the first one:
http://atlas.agr.gc.ca/arcgis/services/ImageServices/IMG_MB_ORTHO_50CM_2009/ImageServer/WMSServer?request=getCapabilities
You can see that the online resource is pointing to:
  http://nlwis-agprd0p.agr.gc.ca/arcgis....
which is for you/me not available (but seems to be an internal address
or so??)
In QGIS output, I can see it tries to pull this url:
http://nlwis-agprd0p.agr.gc.ca/arcgis/services/ImageServices/IMG_MB_ORTHO_50CM_2009/ImageServer/WMSServer?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=48.95022000000000162,-101.71716499999999428,52.39524999999999721,-97.75096700000000283&CRS=EPSG:4326&WIDTH=808&HEIGHT=703&LAYERS=IMG_MB_ORTHO_50CM_2009&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
BUT: a lot of WMS servers are not configured ok, so QGIS has an option
to ignore the url's in the capabilities, but actually use the same host
as the capabilities come from:
In the WMS connection parameters, click the two check boxes:
[v] Ignore GetMap/GetTile URI reported in capabilities
[v] Ignore GetFeatureInfo URI reported in capabilities
THEN I get a map \o/
You can also contact them, and ask them to configure their wms with the
right online resource url ( and ask them to move from arcgis to
qgisserver ;-) ).
Regards,
On 14-05-14 19:09, Bruce, Bob (CWS) wrote:
> I am having a problem access some WMS servers in QGIS. Could someone
> else please have a look at this to see if I am doing something wrong or
> if there is a problem with QGIS?
> I am using QGIS 2.2.0-Valmiera
> I have got it to work on one WMS server, but when I try and connect to:
> it shows it connected and I can add the layer to my view but when I try
> and draw it no map image returns.
> When I try a URL request for a map image to that WMS I do get one, here
> is an example:
> http://atlas.agr.gc.ca/arcgis/services/ImageServices/IMG_MB_ORTHO_50CM_2009/ImageServer/WMSServer?service=WMS&request=GETMAP&version=1.3.0&crs=EPSG:26914&format=image/jpeg&layers=IMG_MB_ORTHO_50CM_2009&styles=&transparent=false&bbox=336636.55,5539116.4,349496.46,5550523.7&width=902&height=801
> so I am stumped as to why I don't see anything in QGIS. I have tried to
> be careful and select the same CRS and image type as the one in my URL
> above and my project is set to the same CRS but still no map image returns.
> Is this a QGIS problem or something that I'm doing?
> thanks,
>            Bob Bruce
> Qgis-user mailing list
