[Qgis-user] displaying values on range slider widget
McDonaldR
McDonaldR at angus.gov.uk
Tue May 20 03:57:03 PDT 2014
Hello List
I'm getting that loving feeling from creating custom feature forms for a tree survey in QGIS and I really like the various edit widgets available. Using the range widget I have the option to have an editable box, a slider and a dial to select my tree height.
Is it possible to display the values I have selected using the widget? So, slide the handle along until, say, "7" and have "7" display next to/above. At the moment I can use the slider but have to count as I go as there is no feedback.
If my field is an integer then I can have both a dial and slider and it is constrained to increment by 1. The widget displays as a slider or dial.
If my field is a real number then I only have a slider option but I can also set the step to anything I like. However, the widget does not display as a slider but rather as an editable field with stepper controls. Is this correct?
I am using the nightly development build of QGIS (2.3.0 / afce05)
Any pointers?
Many thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk> | W: Angus Maps<http://www.angus.gov.uk/maps/map_home.cfm>
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140520/d1fca275/attachment.html>
