[Qgis-user] displaying values on range slider widget
Paolo Cavallini cavallini at faunalia.it
Tue May 20 04:34:32 PDT 2014
Il 20/05/2014 12:57, McDonaldR ha scritto:
> If my field is a real number then I only have a slider option but I can
> also set the step to anything I like.  However, the widget does not
> display as a slider but rather as an editable field with stepper
> controls.  Is this correct?
Hi.
As far as I remember there are a few tickets open about this. Could you
please check and add your comments there?
It would greatly speed up a solution if you could support the fix somehow.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
