[Qgis-user] displaying values on range slider widget
McDonaldR McDonaldR at angus.gov.uk
Tue May 20 04:48:56 PDT 2014
You're right - it is all happening here: http://hub.qgis.org/issues/4417
Ross
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 20 May 2014 12:35
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] displaying values on range slider widget
Il 20/05/2014 12:57, McDonaldR ha scritto:
> If my field is a real number then I only have a slider option but I
> can also set the step to anything I like.  However, the widget does
> not display as a slider but rather as an editable field with stepper
> controls.  Is this correct?
Hi.
As far as I remember there are a few tickets open about this. Could you please check and add your comments there?
It would greatly speed up a solution if you could support the fix somehow.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons.  Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
