[Qgis-user] GDAL extension, filegdb, in QGIS
Etienne Tourigny
etourigny.dev at gmail.com
Tue May 20 08:37:08 PDT 2014
On Tue, May 20, 2014 at 12:24 PM, john polo <jpolo at mail.usf.edu> wrote:
> I know this has been asked before and I have read a few threads about
> this, but I still can't figure out what to do. I am using a 64 bit Windows
> 7 machine. I have uninstalled and reinstalled QGIS via the Advanced Install
> from OSGEO. I selected the library for filegdb to install with QGIS (2.2).
> I have a gdb saved from ArcGIS 10.1. I select Add Vector>Directory and
> under type there is no option for ArcGIS gdb or whatever it should say. I
> browse to the gdb anyway and select it and then QGIS tells me that the file
> is an invalid data source.
> I checked Settings>Options>GDAL and I don't see filegdb in the list. I
> checked GDAL_DRIVER_PATH and the path goes straight to the directory with
> ogr_FileGDB.dll. It appears the that library is installed, but QGIS is
> still not using it to recognize gdb. I am not sure what to do, so I would
> welcome any possible suggestions.
that only shows the available GDAL Raster drivers, not the (OGR) vector
drivers. But this does not solve your problem.
> John
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140520/01231620/attachment.html>
