[Qgis-user] GDAL extension, filegdb, in QGIS
Andre Joost andre+joost at nurfuerspam.de
Tue May 20 09:13:45 PDT 2014
Am 20.05.2014 17:24, schrieb john polo:
> I know this has been asked before and I have read a few threads about
> this, but I still can't figure out what to do. I am using a 64 bit
> Windows 7 machine. I have uninstalled and reinstalled QGIS via the
> Advanced Install from OSGEO. I selected the library for filegdb to
> install with QGIS (2.2). I have a gdb saved from ArcGIS 10.1. I select
> Add Vector>Directory and under type there is no option for ArcGIS gdb or
> whatever it should say. I browse to the gdb anyway and select it and
> then QGIS tells me that the file is an invalid data source.
This site:
<http://www.northrivergeographic.com/qgis-using-esris-file-based-geodatabase>
suggests not to use the latest version 1.11 of filegdb, but 1.10.1-2
I have no filegdb to test it myself.
> I checked Settings>Options>GDAL and I don't see filegdb in the list.
These are raster formats only, so filegdb won't show up there.
HTH,
André Joost
