[Qgis-user] GDAL extension, filegdb, in QGIS
    john polo
    jpolo at mail.usf.edu
    Tue May 20 12:25:35 PDT 2014
André,
Your suggestion:
"This site:
<http://www.northrivergeographic.com/qgis-using-esris-file-based-geodatabase>
suggests not to use the latest version 1.11 of filegdb, but 1.10.1-2
I have no filegdb to test it myself."
... worked perfectly for me.
Much obliged,
John
On 5/20/2014 10:24 AM, john polo wrote:
> I know this has been asked before and I have read a few threads about
> this, but I still can't figure out what to do. I am using a 64 bit
> Windows 7 machine. I have uninstalled and reinstalled QGIS via the
> Advanced Install from OSGEO. I selected the library for filegdb to
> install with QGIS (2.2). I have a gdb saved from ArcGIS 10.1. I select
> Add Vector>Directory and under type there is no option for ArcGIS gdb
> or whatever it should say. I browse to the gdb anyway and select it
> and then QGIS tells me that the file is an invalid data source.
> I checked Settings>Options>GDAL and I don't see filegdb in the list. I
> checked GDAL_DRIVER_PATH and the path goes straight to the directory
> with ogr_FileGDB.dll. It appears the that library is installed, but
> QGIS is still not using it to recognize gdb. I am not sure what to do,
> so I would welcome any possible suggestions.
> John
