[Qgis-user] GDAL extension, filegdb, in QGIS
Alex Mandel
tech_dev at wildintellect.com
Tue May 20 12:40:39 PDT 2014
How does the new OpenFilegdb driver play into this?
http://www.gdal.org/ogr/drv_openfilegdb.html
Thanks,
Alex
On 05/20/2014 12:25 PM, john polo wrote:
> André,
> Your suggestion:
> "This site:
> <http://www.northrivergeographic.com/qgis-using-esris-file-based-geodatabase>
> suggests not to use the latest version 1.11 of filegdb, but 1.10.1-2
> I have no filegdb to test it myself."
> ... worked perfectly for me.
> Much obliged,
> John
> On 5/20/2014 10:24 AM, john polo wrote:
>> I know this has been asked before and I have read a few threads about
>> this, but I still can't figure out what to do. I am using a 64 bit
>> Windows 7 machine. I have uninstalled and reinstalled QGIS via the
>> Advanced Install from OSGEO. I selected the library for filegdb to
>> install with QGIS (2.2). I have a gdb saved from ArcGIS 10.1. I select
>> Add Vector>Directory and under type there is no option for ArcGIS gdb
>> or whatever it should say. I browse to the gdb anyway and select it
>> and then QGIS tells me that the file is an invalid data source.
>> I checked Settings>Options>GDAL and I don't see filegdb in the list. I
>> checked GDAL_DRIVER_PATH and the path goes straight to the directory
>> with ogr_FileGDB.dll. It appears the that library is installed, but
>> QGIS is still not using it to recognize gdb. I am not sure what to do,
>> so I would welcome any possible suggestions.
>> John
> Qgis-user mailing list
