[Qgis-user] Shape file displays distorted when panning
Andreas Neumann
a.neumann at carto.net
Wed May 21 04:12:05 PDT 2014
My guess it is that it may have to do with the builtin on-the-fly
feature simplification. Did you try to disable that? See "Options ->
Rendering -> Enable feature simplification ...". Does the problem
persist if this is set to disabled?
The Antialising should not affect the geometry, so I don't think it has
to do with the setting "Make lines appear less jagged ..."
Andreas
Am 21.05.2014 09:30, schrieb magerlin:
> I think I found the answer myself:
> Unchecking "Make lines appear less jagged at the expense of some drawing
> performance" in "Options | Rendering" turns on the distortion of the shape
> files.
> Is this a bug?
> Regards Morten
> Currently using Qgis 2.2 (OSGeo4),
> Windows 7, 64bit
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Shape-file-displays-distorted-when-panning-tp5141573p5141580.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
