[Qgis-user] How to zoom smooth or stepless?
Alex Mandel
tech_dev at wildintellect.com
Wed May 21 11:44:44 PDT 2014
You should also be able to draw the zoom with the + enabled or specify
the scale by typing in the box at the bottom. There's also list of
scales on the bottom box for common scales.
Enjoy,
Alex
On 05/21/2014 11:28 AM, Etienne Tourigny wrote:
> You can try zooming to a specific regions with the zoom in (with a + sign).
> The default zoom factor is 2, this can be changed in options->map
> tools->panning and zooming.
> This may be a bit different with qgis 1.8 - by the way you should try out
> the 2.2 version!
> On Wed, May 21, 2014 at 12:10 PM, Thomas Schweser <
> Schweser at planungsbuero-petrick.de> wrote:
>> Hi.
>> I’ll keep it short:
>> OS: Win7, 64bit
>> QGIS-Version: 1.8.0-Lisboa (german)
>> I am using a self-generated CRS based on ETRS89/ Zone32 (EPSG:25832):
>> +proj=tmerc +lat_0=0 +lon_0=15 +k=0.9996 +x_0=3500000 +y_0=0 +ellps=GRS80
>> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
>> Each time I try to zoom into this map (using WMS, URL:
>> http://isk.geobasis-bb.de/ows/dtk10.php) (or any other map/ layer) its
>> only possible for discrete steps:
>> Scale -> 1:72224 – 1:36112 – 1:18056 and so on.
>> What did I miss to configure or to set? Or is it “normal”?
>> Thanks for any help
>> Thomas
