[Qgis-user] OGR and DWG
Zoltan Szecsei
zoltans at geograph.co.za
Thu May 22 02:46:23 PDT 2014
Ah, on the gdal/ogr website it says that "most" dwg formats are readable
- Now that you mention the teigha word, I've re-read the page:
http://www.gdal.org/ogr/drv_dwg.html
Thanks for the wake-up call.
Regards,
Zoltan
On 2014/05/22 11:35, Andreas Neumann wrote:
> Hi,
> No - there is no chance. Not supported. DWG is a closed format without
> documentation. Your only chance is to install the Teigha library and
> recompile OGR to use Teigha to read DWG (http://www.opendesign.com/).
> Andreas
> Am 22.05.2014 09:30, schrieb Zoltan Szecsei:
>> Hi,
>> I'm wanting to convert a DWG file to (almost) anything.
>> Neither QGIS nor ogrinfo will open it.
>> On Ubuntu 14.04 ogrinfo --version returns GDAL 1.10.1 2013/08/26
>> Will getting a newer version help, or what else can I try?
>> Thanks & regards,
>> Zoltan
> Qgis-user mailing list
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
