[Qgis-user] Changing Scale factor
Zoltan Szecsei zoltans at geograph.co.za
Thu May 22 04:35:11 PDT 2014
I've got a DXF file wherein the coordinate numbers (values) need to be
divided by 1000 on each axis.
I can't see anything in ogr2ogr - unless there is a trick using -t_srs
parameter and defining a custom CRS?
The numeric values are currently in mm but I need to have them in metres
so that I can assign the correct CRS to them.
TIA,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
