[Qgis-user] Changing Scale factor
Richard McDonnell richard.mcdonnell at opw.ie
Thu May 22 04:52:27 PDT 2014
The simplest method (for me) would be to use CAD package to scale the
map down by a factor of 0.001 and move it to the correct coordinates.
There are a number of free CAD packages available, NanoCAD being my
personal favourate, it can be downloaded at http://nanocad.com/
Regards,
Richard
On 22/05/2014 12:35, Zoltan Szecsei wrote:
> Hi,
> I've got a DXF file wherein the coordinate numbers (values) need to be
> divided by 1000 on each axis.
> I can't see anything in ogr2ogr - unless there is a trick using -t_srs
> parameter and defining a custom CRS?
> The numeric values are currently in mm but I need to have them in
> metres so that I can assign the correct CRS to them.
> TIA,
> Zoltan
Email Disclaimer: http://www.opw.ie/en/disclaimer/
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140522/91329115/attachment.vcf>
