[Qgis-user] Changing Scale factor
Andreas Neumann
a.neumann at carto.net
Thu May 22 04:57:54 PDT 2014
There is a plugin called "Affine Transformations". If it is a scale
change and simple shift and you know the parameters, this may work.
I hope that QGIS will have a vector georeferences some day, similar to
the raster georeferencer. Until that you will have to use the more
complicated way through the Affine transformations plugin.
Andreas
Am 22.05.2014 11:35, schrieb Zoltan Szecsei:
> Hi,
> I've got a DXF file wherein the coordinate numbers (values) need to be
> divided by 1000 on each axis.
> I can't see anything in ogr2ogr - unless there is a trick using -t_srs
> parameter and defining a custom CRS?
> The numeric values are currently in mm but I need to have them in metres
> so that I can assign the correct CRS to them.
> TIA,
> Zoltan
