[Qgis-user] Changing Scale factor
Etienne Tourigny etourigny.dev at gmail.com
Thu May 22 07:01:27 PDT 2014
You might be able to use ogr2ogr -a_srs (not -t_srs) with a custom crs
On Thu, May 22, 2014 at 8:35 AM, Zoltan Szecsei <zoltans at geograph.co.za>wrote:
> Hi,
> I've got a DXF file wherein the coordinate numbers (values) need to be
> divided by 1000 on each axis.
> I can't see anything in ogr2ogr - unless there is a trick using -t_srs
> parameter and defining a custom CRS?
> The numeric values are currently in mm but I need to have them in metres
> so that I can assign the correct CRS to them.
> TIA,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax:    +27-86-6115323     www.geograph.co.za
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140522/07818259/attachment.html>
