[Qgis-user] Changing Scale factor
Zoltan
zoltans at geograph.co.za
Thu May 22 07:18:14 PDT 2014
On 22/05/2014 16:01, Etienne Tourigny wrote:
> You might be able to use ogr2ogr -a_srs (not -t_srs) with a custom crs
Yep! - Exactly what I just tried (note the +k parameter)
-s_srs "+proj=tmerc +lat_0=0 +lon_0=29 +k=1000 +x_0=0 +y_0=0 +axis=enu
+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
-t_srs "+proj=tmerc +lat_0=0 +lon_0=29 +k=1 +x_0=0 +y_0=0
+axis=enu +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
Thanks to everyone who contributed.
Regards,
Zoltan
> On Thu, May 22, 2014 at 8:35 AM, Zoltan Szecsei
> <zoltans at geograph.co.za <mailto:zoltans at geograph.co.za>> wrote:
> Hi,
> I've got a DXF file wherein the coordinate numbers (values) need
> to be divided by 1000 on each axis.
> I can't see anything in ogr2ogr - unless there is a trick using
> -t_srs parameter and defining a custom CRS?
> The numeric values are currently in mm but I need to have them in
> metres so that I can assign the correct CRS to them.
> TIA,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028 <tel:%2B27-83-6004028>
> Fax: +27-86-6115323 <tel:%2B27-86-6115323> www.geograph.co.za
> <http://www.geograph.co.za>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Geograph (Pty) Ltd.
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140522/e2f201be/attachment.html>
