[Qgis-user] fedora 20: MISSING SAGA MODULE LIBRARY
Andrea Spisni aspisni at arpa.emr.it
Fri May 23 00:35:16 PDT 2014
i'm using fedora 20 and I'm trying to work with saga module.
When I try to start them I obtain the error
Missing dependency.This algorithm cannot be run :-(
This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA
is not installed in your system, or it is not correctly configured to be
used from QGIS
I think the issue is related to a missing setting of saga module
library, but I don't know how to fix it.
Saga is installed and if I start it as a stand alone I need to manually
load the modules from /usr/lib64/saga folder.
Which is the name of the saga module library variable?
Thanks
Andrea Spisni
Area Agrometeorologia, Territorio e Clima
Servizio IdroMeteoClima
Agenzia Regionale Prevenzione e Ambiente dell'Emilia-Romagna
V.le Silvani, 6 - 40122 Bologna Italia
Tel. +39 051 649 75 61
Fax. +39 051 649 75 01
http://www.arpa.emr.it/sim/?telerilevamento
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140523/f08ae6b9/attachment.html>
