[Qgis-user] fedora 20: MISSING SAGA MODULE LIBRARY
Volker Fröhlich volker27 at gmx.at
Sat May 24 07:57:31 PDT 2014
Am 2014-05-23 09:35, schrieb Andrea Spisni:
> Hi,
> i'm using fedora 20 and I'm trying to work with saga module.
> When I try to start them I obtain the error
> Missing dependency.This algorithm cannot be run :-(
> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA
> is not installed in your system, or it is not correctly configured to be
> used from QGIS
> I think the issue is related to a missing setting of saga module
> library, but I don't know how to fix it.
> Saga is installed and if I start it as a stand alone I need to manually
> load the modules from /usr/lib64/saga folder.
> Which is the name of the saga module library variable?
> Thanks
> Andrea Spisni
> Area Agrometeorologia, Territorio e Clima
> Servizio IdroMeteoClima
> Agenzia Regionale Prevenzione e Ambiente dell'Emilia-Romagna
> V.le Silvani, 6 - 40122 Bologna Italia
> Tel. +39 051 649 75 61
> Fax. +39 051 649 75 01
> aspisni at arpa.emr.it
> http://www.arpa.emr.it/sim/?telerilevamento
Please let me know if a change in either Saga or QGIS is necessary. I
maintain both packages in Fedora. I remember trying that at some point,
but I can't remember the details.
Greetings,
Volker
