[Qgis-user] Csv file.
João Gaspar joao.f.r.gaspar at gmail.com
Mon May 26 09:52:18 PDT 2014
Yes i confirm this behavior with numbers, with the text fields works ok.
Test in QGIS 2.2 Valmiera OSGeo4W 32-bits Installer in Windows 7 64-bits.
Alexandre, do you have the same behavior?
Regards
João
2014-05-26 17:36 GMT+01:00 Ourizo Cacho <usuario7 at gmx.es>:
>  Sure,
> the situation could be:
> csv file content:
> NAME,2013,2014
> REGION1,"1000","2000"
> REGION2,"3000","4000"
> I try to add this file into QGIS as an only table, with no geometries
> associated and the result I get is like this:
> NAME,field_2,field_3
> El 26/05/2014 18:26, Alexandre Neto escribió:
>  Hello,
>  can you please send a sample of your csv file?
>  Alexandre Neto
> On Mon, May 26, 2014 at 5:24 PM, Ourizo Cacho <usuario7 at gmx.es> wrote:
>> Hello everyone,
>> I have a *csv file that I´m trying to add as an attribute only table. The
>> question is that QGIS only recognizes the name of the first field. The
>> others are named, field_2, field_3 and so on... The rest of the table,
>> including attibutes are ok.
>> How can I get the correct names of the fields into a new QGIS attribute
>> table??
>> Any help, please?
>> Este mensaje no contiene virus ni malware porque la protección de avast!
>> Antivirus está activa.
>> http://www.avast.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>    <http://www.avast.com/>
> Antivirus <http://www.avast.com/> está activa.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140526/6aa6db47/attachment.html>
