[Qgis-user] Split concentric polygons with a unique function
Richard McDonnell richard.mcdonnell at opw.ie
Tue May 27 02:02:48 PDT 2014
under Vector=>Data Management=>Split Vector Layer. It allows you to
specify a unique Field to split the vector on. They don't appear to be
concentric, more one on top of the other, one method would be to add a
ring, also make the shapefile transparent, this will show areas which
are not islands/rings.
Hope this answers your question.
Regards,
Richard.
On 27/05/2014 09:39, Paolo Antonelli wrote:
> Hi,
> i have a polygonal shapefile consists of 10 concentric areas. The
> column ID of this shp identifies these 10 polygons.Â
> Immagine in linea 1
> There is a feature that allows you to split each polygon based on the
> remaining polygons, using the field ID?Â
> In this case, for several reason, I cannot use "Delete ring"
> Many thanks,
> paolo
> Qgis-user mailing list
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/da190a3d/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/da190a3d/attachment.jpe>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/da190a3d/attachment.vcf>
