[Qgis-user] Split concentric polygons with a unique function
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue May 27 02:28:07 PDT 2014
you can use the Digitizing Tools Plugin "Cut with polygon from another
layer" tool to achieve this. Load the layer twice into QGIS one is for
editing, the other to cut with.
Backup your data until you know how the tool works.
Bernhard
Am 27.05.2014 11:05, schrieb Paolo Antonelli:
> i'm apologize, I meant to say a difference
> 2014-05-27 10:44 GMT+02:00 G. Allegri <giohappy at gmail.com
> <mailto:giohappy at gmail.com>>:
> What do you mean with "splitting"?
> Do you mean perform difference? E.g. make polygon id=1 become a
> polygon with a hole defined by polygon with id=2?
> Or do you mean splitting into several layers?
> giovanni
> 2014-05-27 10:39 GMT+02:00 Paolo Antonelli
> <geol.paoloantonelli at gmail.com <mailto:geol.paoloantonelli at gmail.com>>:
> Hi,
> i have a polygonal shapefile consists of 10 concentric areas.
> The column ID of this shp identifies these 10 polygons.
> Immagine in linea 1
> There is a feature that allows you to split each polygon based
> on the remaining polygons, using the field ID?
> In this case, for several reason, I cannot use "Delete ring"
> Many thanks,
> paolo
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
__________ Information from ESET Mail Security, version of virus signature database 9853 (20140527) __________
The message was checked by ESET Mail Security.
http://www.eset.com
