[Qgis-user] Split concentric polygons with a unique function
Paolo Antonelli geol.paoloantonelli at gmail.com
Tue May 27 02:05:48 PDT 2014
i'm apologize, I meant to say a difference
2014-05-27 10:44 GMT+02:00 G. Allegri <giohappy at gmail.com>:
> What do you mean with "splitting"?
> Do you mean perform difference? E.g. make polygon id=1 become a polygon
> with a hole defined by polygon with id=2?
> Or do you mean splitting into several layers?
> giovanni
> 2014-05-27 10:39 GMT+02:00 Paolo Antonelli <geol.paoloantonelli at gmail.com>
>> Hi,
>> i have a polygonal shapefile consists of 10 concentric areas. The column
>> ID of this shp identifies these 10 polygons.
>> [image: Immagine in linea 1]
>> There is a feature that allows you to split each polygon based on the
>> remaining polygons, using the field ID?
>> In this case, for several reason, I cannot use "Delete ring"
>> Many thanks,
>> paolo
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/e6093271/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/e6093271/attachment.jpe>
