[Qgis-user] Split concentric polygons with a unique function
G. Allegri giohappy at gmail.com
Tue May 27 01:44:20 PDT 2014
What do you mean with "splitting"?
Do you mean perform difference? E.g. make polygon id=1 become a polygon
with a hole defined by polygon with id=2?
Or do you mean splitting into several layers?
giovanni
2014-05-27 10:39 GMT+02:00 Paolo Antonelli <geol.paoloantonelli at gmail.com>:
> Hi,
> i have a polygonal shapefile consists of 10 concentric areas. The column
> ID of this shp identifies these 10 polygons.
> [image: Immagine in linea 1]
> There is a feature that allows you to split each polygon based on the
> remaining polygons, using the field ID?
> In this case, for several reason, I cannot use "Delete ring"
> Many thanks,
> paolo
> Qgis-user mailing list
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/57055c21/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/57055c21/attachment.jpe>
