[Qgis-user] Split concentric polygons with a unique function
Paolo Antonelli geol.paoloantonelli at gmail.com
Tue May 27 01:39:10 PDT 2014
i have a polygonal shapefile consists of 10 concentric areas. The column ID
of this shp identifies these 10 polygons.
[image: Immagine in linea 1]
There is a feature that allows you to split each polygon based on the
remaining polygons, using the field ID?
In this case, for several reason, I cannot use "Delete ring"
Many thanks,
paolo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/7dd562e3/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/7dd562e3/attachment.jpe>
