[Qgis-user] QGIS Opening simple Ascii X,Y,Z terrain data
Goyo goyodiaz at gmail.com
Tue May 27 11:22:13 PDT 2014
2014-05-27 19:15 GMT+02:00 Rudy VanDrie <rudy at balancernd.com.au>:
> Thanks Goyo...
> are you opening as a delimited Text or something else?
> What is the file extension you are using?
> What format does QGIS think it is opening??
I mean ASCII Gridded XYZ [1]. If the extension is .xyz QGIS will try
to load it as that kind of file. Otherwise you can tell QGIS the file
type in the open raster dialog.
Goyo
[1] http://www.gdal.org/frmt_xyz.html
