[Qgis-user] Importing open street map .osm files
Clifford Snow clifford at snowandsnow.us
Tue May 27 08:27:14 PDT 2014
On Tue, May 27, 2014 at 8:12 AM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> This is only useful with QGIS for the smaller areas. The larger files
> should be filled directly into a Postgis database with osm2pgsql.
> Another choice is to use GDAL to populate a spatialite db outside of QGIS,
> or use Add vector layer inside QGIS (again only useful for small areas).
I usually use overpass-turbo with results returned as a geojson. Geojson
file open directly in QGIS. I've not has especially good luck getting OSM
data using QGIS, but that could easily be my inexperience.
Clifford
@osm_seattle
osm_seattle.snowandsnow.us
OpenStreetMap: Maps with a human touch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/0be52840/attachment.html>
