[Qgis-user] Qgis 2.3 nightly build in Mavericks
Larry Shaffer larrys at dakotacarto.com
Wed May 28 17:52:16 PDT 2014
The Mac QGIS nightly site has been updated:
http://qgis.dakotacarto.com/
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Wed, May 28, 2014 at 4:57 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Sergio,
> Thank you for reporting.
> On Wed, May 28, 2014 at 1:20 PM, Sergio Zárate <acac09 at gmail.com> wrote:
>> Hello all, I tried to open the nightly build of Qgis 2.3 in MacBookPro
>> using OS X 10.9.3  and got the following message of error:
>> Process:         QGIS_2.3-dev [1348]
>> Path:
>>  /Applications/QGIS_2.3-dev.app/Contents/MacOS/QGIS_2.3-dev
>> Identifier:      org.qgis.qgis-dev
>> Version:         ???
>> Code Type:       X86-64 (Native)
>> Parent Process:  launchd [271]
>> Responsible:     QGIS_2.3-dev [1348]
>> User ID:         501
>> Date/Time:       2014-05-28 14:16:53.882 -0500
>> OS Version:      Mac OS X 10.9.3 (13D65)
>> Report Version:  11
>> Anonymous UUID:  362E5C02-C39F-AF3E-4664-86A62C4FD245
>> Sleep/Wake UUID: 916C2639-55E0-45CB-B785-748DD2E48979
>> Crashed Thread:  0
>> Exception Type:  EXC_BREAKPOINT (SIGTRAP)
>> Exception Codes: 0x0000000000000002, 0x0000000000000000
>> Application Specific Information:
>> dyld: launch, loading dependent libraries
>> Dyld Error Message:
>>   Library not loaded:
>> /Library/Frameworks/GDAL.framework/Versions/1.11/GDAL
> As this error indicates, you need to update to the latest GDAL 1.11
> Complete framework from Kyngchaos.com [0]. Sorry, I finished upgrading the
> build server with that framework yesterday, but did not have time to update
> the nightly website with this information. Will do so today.
> [0] http://www.kyngchaos.com/software/frameworks
> Regards,
> Larry Shaffer
> Dakota Cartography
>   Referenced from:
>>   Reason: image not found
>> Binary Images:
>>     0x7fff68c1c000 -     0x7fff68c4f817  dyld (239.4)
>> <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
>> Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core
>> i5, 2.3 GHz, 4 GB, SMC 1.68f99
>> Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
>> Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
>> 0x4D34373142353737334448302D4348392020
>> Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE,
>> AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6),
>> Broadcom BCM43xx 1.0 (5.106.98.100.22)
>> Bluetooth: Version 4.2.4f1 13674, 3 services, 23 devices, 1 incoming
>> serial ports
>> Network Service: AirPort, AirPort, en1
>> Serial ATA Device: Hitachi HTS545032B9A302, 320.07 GB
>> Serial ATA Device: MATSHITADVD-R   UJ-898
>> USB Device: FaceTime HD Camera (Built-in)
>> USB Device: Hub
>> USB Device: Apple Internal Keyboard / Trackpad
>> USB Device: BRCM2070 Hub
>> USB Device: Bluetooth USB Host Controller
>> USB Device: Hub
>> USB Device: IR Receiver
>> Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
>> So, I can not try it!
>> Regards
>> Sergio Zárate
>> Dr. Sergio Zárate Pedroche
>> José María Arroyo 228
>> Col. 22 de octubre
>> Morelia, Michoacán
>> C.P. 58341
>> México
>> Teléfono: (443) 352-5307
>> Celular: (443)  438-6212
>> http://independent.academia.edu/SergioZ%C3%A1ratePedroche
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140528/684bb2d2/attachment.html>
